Minor Upgrade Part Two - HID DRL w/Pix
Correct. If you got the relay harness exactly like mines, it has both the passenger and driver side. Just unplug the factory plug (then tie it away), run the wiring to the driver side. I ran it along above the radiator (the air intake tupperware will cover up the wiring).
those look like 3k's... or non heated up 6k's...
Note: Leave HID's on for at least 8 minutes after initial installation to burn off any oils that may have accumalated on the bulb itself...
Now if you can wire up DRL with the fogs on at the same time, that would be a sight to see.
More update
Now that fall is getting close, I decided to swap the 6000k DRL HID Bulb (left hand side in image below) to a 3000k color (right hand side) You can really tell the difference. The replacement bulbs were super inexpensive, only $13 shipped for the pair. Swap out was pretty easy, took about 10 minutes for both side. See below.
i connected the factory plugs to ballast and alli get is a flicker unles i turn on the high beam than they come on. but when i put it on drive and turn off the high beam the bulb just flickers. so i bought the v-leds modules 2 of them since they said those modules bump up the voltage to 12v and it still flickers. i connect the factory plug to module and the other end to the ballast on both driver and passenger side. and it still flickers. i also have the relay and tried the relay which connects to battery. one wire to the battery and the 2 plugs to the ballast and it still flickers. i'm lost
