Air suspension?
Sup every one so have a custom lux with air and a data controller and I'm not really satisfied with the hight all the way down. Does anyone know how I can get it lower or how to adjust the hight sensors. Plz instructions w/pics if possible thanks
Stevie Wonder could adjust the height sensors! Its so easy! For the front, twist your senors rods to compress the ends closer to one another (I hacked sawed a half inch off my rods and welded them back together to get it even lower) As for the rear, just get a 10mm socket wrench and move the bolts all the way down. I slammed my car for 0$ without sacrificing ride comfort, and I can raise it whenever I please.
After each adjustment, give it a good 2minutes to adjust, take for a ride, adjust accordingly, repeat until you get it leveled out. Easier done than said, seriously
He has a data systems controller. He doesnt need to mess with the sensors unless his car is sitting uneven. Take it to Revision and let them adjust the setting on the controller to get it where you want. Just remember driving around with the bags low on air will cause it to go bad faster.
^ LMAO
adjusting them is easy,, getting it right (= level on all 4 sides) is excruciatingly intensive.
having adjusted your UL to sit much lower via the rods and sensors and having all 4 perfectly level (better than factory) = priceless!!!
