Rear air struts
Old 06-02-11, 05:02 PM
Griff48
Griff48's Avatar
Default Rear air struts
After taking my '04 LS430 UL to two dealers (one Lexus and one Toyota)only to be told my air suspension is fine, I have figured out that my left rear shock absober is shot at 73k miles. If I go over a speed bump with the right rear wheel everything is fine. When I do the same with the left rear wheel the suspension crashes to the stops.
That said, I went online to Sewell and the parts are not available online. That is my luck. So, how are other guys buying rear suspension parts?
Thanks for any help.
Gene
Old 06-02-11, 05:29 PM
HiloDB1
HiloDB1's Avatar
There are a few people selling stock air struts in the classifieds. If you dont mind buying used. Most people end up going aftermarket air or converting to coils when their stock air goes bad. I know Im going aftermarket soon as my stock air starts going bad.
Old 06-02-11, 10:04 PM
Griff48
Griff48's Avatar
Thanks, I'll check there. Trying to stay stock, much as I can.
Gene
Old 06-03-11, 09:58 AM
votru
votru's Avatar
Do try to pm Darrel (Sewell) here as they should carry the struts.
Old 06-03-11, 03:49 PM
Griff48
Griff48's Avatar
I did talk with Darrel this morning. Air struts are among a number of parts that are under restriction, ie- not available online. These parts are in short supply due to the earthquake/tsunami in Japan. He had no estimate for new stock.
Gene
Old 06-07-11, 06:19 PM
Griff48
Griff48's Avatar
I found a set of rear air struts at a different Lexus parts place; ~$880ea plus shipping. Now the big question.....how hard are these to install? Or should I find an independent shop to do the honors? Thanks for any advice.
Gene
Vmost66
01-15-23 07:40 AM
Martie841
11-28-18 01:41 AM
davidma415
05-12-17 07:53 AM
Lexs400
05-09-07 07:20 PM
Quick Reply: Rear air struts
