Intermittent steering shake upon braking
Old 06-01-12 | 03:30 PM
  #31
Bocatrip's Avatar
Bocatrip
My mechanic told me that althrough he could turn the rotors again, he would suggest getting new Lexus rotors. He told me that it is not unusual for toyota rotors to warp easily. He purchased a new Tacoma and after 3,000 miles he got the steering wheel shake on braking. He turned the rotors and it was fine until he replaced the pads and then it came back. He now has 150,000 miles and has learned to live with the shaking after all this time. I would like to know if there is toyota vehicle using the same Lexus part number to save a view bucks. Does anyone know?
Old 06-01-12 | 08:10 PM
  #32
jayclapp's Avatar
jayclapp
I wouldn't have anything to do with aftermarket rotors or pads or mechanics. My car drives and operates like silk and has never seen any aftermarket parts or service by anyone other than Lexus.
Old 01-25-16 | 07:46 PM
  #33
philnshelb's Avatar
philnshelb
Originally Posted by Jim_Chow
I wouldn't bother turning the rotors. It just means there's less metal to dissipate the heat, meaning they will "warp" soon thereafter. It's better to replace the rotors and pads together. Make sure to bed the pads in well. Also make sure the calipers are torqued correctly. You need to replace the aluminum caliper bolts since they are single use.
Did you say caliper bolts are aluminium and one use, reason i ask is i read one member on here fixed the vibration by removing and applying high temp caliper grease to bolts. Do you know the torque spec for bolts and where is best place to get replacement bolts.
Old 01-25-16 | 07:51 PM
  #34
BMW7_LS430's Avatar
BMW7_LS430
Bolts or pins?
It was probably pins. Our bolts don't slide like some other designs.
Old 01-25-16 | 07:58 PM
  #35
philnshelb's Avatar
philnshelb
Originally Posted by BMW7_LS430
Bolts or pins?
I have not done brakes on this car but understand by whatever name i am going to lube the piece that moves/slides, so do you know "if the bolts are one time use?"and or their torque spec?" BC that was the real question
Old 01-26-16 | 05:01 PM
  #36
BMW7_LS430's Avatar
BMW7_LS430
Bolts are supposed to be one time use but I have reused them.
Pins are the ones you want to high temp caliper grease on. They hold the metal piece that holds brakes and brakes need to move freely when applied.
Old 01-26-16 | 05:22 PM
  #37
philnshelb's Avatar
philnshelb
Default brake slides
Got it thanks
kambam3627
04-12-19 01:23 PM
Tech
GX - 1st Gen (2003-2009)
13
03-20-14 04:05 PM
SerasLibre
11-15-10 01:23 PM
JohnLX300
RX - 1st Gen (1999-2003)
16
02-12-10 12:19 AM
rclab1
07-17-07 12:51 AM
Quick Reply: Intermittent steering shake upon braking
