where is the sensor located ....
Does anyone happen to know where the sensor is that measures the outside temperature ?
Is it in the engine compartment ?
If you go to l-tunedparts.com (carson toyota/lexus) and select front bumper, then bumper and components, then temp sensor you can see that it is part of the front bumper assembly and costs $13.54. However it is not clear as to where it is actually located. When I look down in the area in front of the radiator I do not see the sensor. I assume that means it is located below that area and between it and the lower underbody panel or tray.
