LS430 is slow to start?
Old 01-12-15, 01:57 AM
low430
low430's Avatar
Ok mine is a 2001 ls430 has about 196ks on it well lookt after car has been nowhere but lexus its hole life.it will start good sometimes but then most of the time it cranks over longer when it starts it runs mint no problims .and one other thing when i take off and put my foot down to 100ks u smell a odd "fart" smell etc for a min or so nothing plays up its just odd maybe the battery??
Old 02-09-24, 08:57 AM
Pegasus430
3rd Gear
Pegasus430's Avatar
SOLVED! I've had this issue since I've had the car and it took some digging to find the answer. While I believe that the car may cycle for lubrication first, I found that my issue with the delayed start was pretty inconsistent. Some days it would crank right up, other days it would be delayed. It was about 50/50 on either normal startup or delayed/cranking startup. I found the delayed start was more common if the vehicle had not already been run that day. I looked further into the Service History on MyLexus and believe I may have found the answer.
My 430 was brought in by the original owner in Aug '04 at 10k miles for the 4LB and 4LC recalls. Googling the recalls, turns out there was a recall on the fuel pumps.
More info: https://repairpal.com/recall/04V295000 .
There is also another report of service in Feb '05 of the owner stating that there was an extended crank on startup. Diagnosed as "valve in fuel pump not sealing properly, replace fuel pump" and the service labeled as "electrical fuel pump assembly."
So maybe the original recall didn't work? Again, still having the same issue this many years later... I don't pay much mind to it anymore as the 430 has never failed to start, but still thought I'd put this out there to give anyone with the problem some peace of mind.
dxbwanted
11-24-18 07:19 AM
Carnut
02-13-11 08:34 PM
ahmed24
02-04-08 12:15 PM
Dew23
08-16-07 11:19 AM
stephenkyu
11-22-04 02:29 PM
Quick Reply: LS430 is slow to start?
