help with my cassette player
If it plays regular cassette it should accept the cassette adapter shell with absolutely no problem. Take a close look at the adapter shell, make sure all parts of it look OK and are not broken or bent, and that the heads, rollers, etc are not bent or misaligned.
make sure you have the right adapter as far as where the heads are. Some are on the short edge and some on the long edge I believe. You want one with the heads on the ong edge. Are you putting it in with the heads facing the correct direction. Just Asking?
