I'm looking to buy an used LS430/400
I'm wondering if buying a 2000 LS430 is better than buying a LS400.
I'm not looking for perfection since my two dogs will be riding in the back. I would never call a Lexus a beater but I need a decent used car under 10,000.
I found a few LS400 for 5-6k with 130k miles.....wow. I don't what repairs will be need on a higher mileage LS.
Any advice you can give me is appreciated.
under 10k and 2 dogs in back = LS400
An LS400 would be your best bet. I really haven't seen many 430s go under 10k (unless the buyer knows the seller). The 430 is more modern, but it also means there are more things to break/go wrong. If you do get a 430, I would suggest getting the base model or premium trim and avoid the nav system (at least $1-2k to repair DIY).
I hear really good things about 400s (and still do a double take when I see one pass, especially a clean '97+ model). They were supposedly the pinnacle of reliability and build quality. Check out the 400 part of CL though before rushing out to buy one as there are quite a few threads that deal with costly failures.
Brakes on the later model year LS400s were much improved over earlier versions
I think that your best bet would be to spend a little extra money and purchase the LS 430 over the 400. Although the 400 is considered a basic smart move as far as reliability, when problems occur, they occur. If you plan on keeping the car for a period of time (how many years in dogs' life) get the LS 430; if you plan on a short run, get the 400. That's how I would approach the situation.
Thanks. I'm looking at the IS300 as well. 2001 can be had for under 7,000. I don't care if the car get beat up a little. I just want a good running car.
Yeah the IS is a pretty small car, about the size of a 3 series (which I had for a bit). I always felt a bit squished at 6 ft, 190 lbs (a bit overweight I know haha, but I'm lazy) and I'm sure my backseat passengers did as well. They're more low slung than you probably imagine so getting a dog inside might turn out to be a PITA. If you're just looking to haul dogs around and use it as a beater, why not something like an older Honda CR-V or Toyota Highlander? Maybe a Subie wagon? Those can be had at less than 10k and will be pretty reliable and much cheaper to fix, maintain and put gas in than an LS.
