05 LS: Warm air through vents when just pulling in outside air
Temperature is finally decent at night here in TX, so I thought I would pull in outside air instead of using the A/C. All I got was warm air even though outside it was 73 degrees. I even cranked down the temp to COLD and it was still blowing warm air.
Anyone else experience this? I hope I don't always have to use the A/C when driving on the interstate even when it's 70 degrees outside!
Why in the world would you not want to use the A/C? Constant temperature at whatever you set it at. I have never turned my A/C off. Use it, that's what's it for, especially in a car like this.
No, I wanted the outside air since it was nice outside, but didn't want to roll down my windows when driving on the freeway. If it's like 70 degrees outside, I don't see any point in running the AC at 68 degrees or 73 degrees and running the compressor. I'd rather bring in the fresh air from outside.
Let me understand better - you had temp at COLD, main climate control Auto light OFF, and the recirculation mode set to vent position (leftmost light IIRC, and the auto recirculation light also OFF) and it was still blowing warm?
Were you in motion? Heat from the road and engine can bring the vent air temps up quickly if not.
Right. I manually turned off the A/C so I could get outside air and the recirculation mode set to vent. I was in fact in motion. I had this same issue in our old 05 FX35, but not in my old 05 G35 or the 06 FX.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
It's unlikely that you'll get 70F outside air into the passenger compartment thru the outside air system. There will probably be some heat input to the ducting from the engine and the blower. If the ducting has heatsoaked to a higher temperature as the car was parked prior to driving, then the relatively low air passing thru the system in a vent situation would take considerable time to cool that ducting. When the outside air temp drops to 55F or lower, then then vent should provide a cooler temp.
This is why I never bother to turn my A/C off. I just set it on auto, forget it, and enjoy the ride.
