Oscillating vents
I recently disconnected my battery in order to clean the posts. After the reconnect I noticed after over a year of ownership that I know have oscillating vents!(center 2 vents) I never knew that my base model (NAV/ML) even had that feature. I like it and was wondering if they can be turned off and if they always oscillate? Pretty Kewl!
Understood. This car is so amazing that it takes several hundred pages to describe all the features in the manual. It is difficult to sit down and read it in entirely at one sitting. And if you mange to get thru it without actually trying those features, it is highly likely that you will forget many, many of them.
It's amazing how smart the oscillating fans are. It knows when you first get in the car to direct only to the driver as you would prefer anyway. I've gone one year without even knowing I had this feature. Surprises Surprises.
Well I'll be darned... so "base" ain't so bad after all. I would have thought minus the NAV screen that they'd just cut the oscillation out, but I guess Lexus thought it was a good enough feature for all to have.
+100 for Lexus.
yup, it has a separate button on the right side of the control panel. i actually love the base model. has everything i need and alot less to go wrong!
Russ G
01-11-08 06:51 AM
splogue
09-24-02 08:19 AM
