My husband screwed up and I'm afraid we are going to have to pay. HELP!
Kwolff123, honnestly just bring the vehicle to the dealership. I dont know why so many of us on here think that its too much to bring to the dealer. They are the ones who are factory trained and know the best about the vehicle. Plus if there is an incedent at the dealer they will cover it. Same thing happened to my uncle - jumped the car backwards and had to bring it to the dealer - they of course have seen this situation before and he was in and out in about an hour - he only had to replace about 4 fuses and was charged a small amount for diagnosis (about 1/2 an hr of labor).
I dont mean to be rude but in a situation like this we do not know the condition of your car and what the other factors are - we cant see it so bring it to somone who can properly fix the vehicle~!
Agree with Ay-Nako.................I was distracted, did same thing to my same car '04 LS430; ouch! Can't begin to remember how many warning lights stayed lit.
Was 120 miles from nearest dealer; able to drive 30-35mph tops; took it to nearest Toyota dealer (still 200 miles from home.)
In 1-1/2 hours , I was on my way, breathing a $5000 sigh of relief.
I'll be honest and say that because of fear, time, and because this car is an extra we have yet to take it to the dealership, but that is on our list for this week. Nc356 and ay-nako, I hope you are right. I can only see $$$ and I don't like it!
I have had this same problem several years ago on a 96LS back in the day. When you connect the terminals backward, you burn the main fuse (should be pink.) Its a ... get ready for this... a whopping $3.0000000-$4.000000 to replace (yes, thats $3-4bucs )
This fuse works to protect the car's ECU and other electrical system in the very event this happens. This fuse is larger rectangular shaped with a clear window from top to allow visual inspection of metal connection piece and can be found in any Discount or advance auto parts shop. You can replace it yourself in 30 seconds one you pop the fuse box cover.
Latest update: technician at Toyota checked all the fuses, one was bad, so the navigation, radio, and air are back on. Yea!!!
But car still will not accelerate and check engine and check vsc are still on. He put in the code to reset it, but they keep coming back on. So,....
I see this pretty often since im a Service advisor for a local Toyota dealership.Alotta times its the tow guys cross jumping it and in some cases the owners cross jump it unknowingly.
The main fuse block (located mostly on the drivers front side) gets blown setting off all three lights.Vehicle will not acclerate beyond certain point or even move for that matter.One of those fuses is for the alternator that gets blown out.
Typically you isolate that issue, address the fuse block(which is still somewhat of a ***** to take out without taking out the whole thing) and put it back together.
Most of the time(and i mean majority) that should be it, however in certain cases if the Malfunction indicator light is still on, with a DTC code for something that is still operational, it is likely that the main ECM(computer) is fried already which can prove to be expensive
Hope it helps and you get things taken care of.
Frankie
(P.S take it to Lexus unless you know somebody at Toyota who is a tech since we can all access the same information that Lexus can
Frankie
Thanks Frankie. This info is encouraging. We had a Toyota tech come to our house to test all the fuses, which is why we didn't go to Lexus. But it seems as though of next step will be getting it towed to Lexus.
Yes, we took it in and there were blown fuses and relays (whatever those are). HUGE sigh of relief! $200 later we were back on the road. Hopefully a mistake that won't be made again. Just glad he did it and not me!
You REALLY should get a multi-meter ($10.00-$15.00) and test all your fuses this will eliminate you from having to take all of them out. I can almost guarantee you have only blown a couple fuses. Check the box under the hood and the one to the left of the gas ped
