low windshield fluid error
I got the message for low wiper fluid so I full the bottle up but the message did not go awe as it usually would. Anyone have any ideas, I am leaning to a bad sensor as I do not have any leaks but does any one know if I need to check anything else. Car is an 04 ls. Thanks
I do not have the headlight washer so I am leaning towards the sensor on the reservoir, I will try to check it this weekend but it goes in for service soon so I will update you on the fix. The red triangle is just annoying.
I made a hammer fist and very firmly tapped on the top of the washer fluid canister about 3 times, and it loosened up the float on the inside. The indicator light went off. Try this before disconnecting anything.
Welcome. I see we graduated from the same school of car repair.
