Alternator Rear Bearing Failing
Old 11-15-11 | 09:20 AM
Marklouis's Avatar
Marklouis
Default Alternator Rear Bearing Failing
For those of you who are experiencing the Drive Belt/Alt squeal even after the replacement of a new belt. the Rear Bearing of the Altenator is what's failing - this is premature for mine is at 75K miles. but I went ahead and replaced the Drive Belt to see what that would do and it still squealed like a banshee, so here is some pics that I took of the work I did.
the front (sealed) bearing was in great shape as also was the alt bushings and main shaft. the rear (failed seal) bearing proved somewhat worn but impossible to remove - but instead of replacing the unit for now i wanted to see if I could make it last a while longer. I used a can of white lithium grease with a straw nozzle and sprayed at the rear base of the bearing while free spinning. after 2 applications of the lithium grease spray it proved to spin more firm and with more revolutions. so I cleaned the leftover grease with MAF cleaner and cleaned the rest of the unit with a high pressure air nozzle. put it all back together close to the original torque specs. I free spinned the main shaft and continued to tighten 1/4 turn on the 4 main casing bolts until I was satisfied with the results.
I put everything back together and cranked it up (after I prayed over my car) and the issue of the squealing is gone albeit the rear bearing will still continue to breakdown but hopefully this will slow the proccess down. I have driven the car everyday since and so far all is well. but as soon as it gives me issues I will be sure and post when and the mileage.
Attached Thumbnails Alternator Rear Bearing Failing-alt-parts.jpg   Alternator Rear Bearing Failing-main-alt.jpg   Alternator Rear Bearing Failing-bushing-shaft.jpg   Alternator Rear Bearing Failing-alt-bushings.jpg
Old 11-15-11 | 01:07 PM
Jabberwock's Avatar
Jabberwock
Nice info with good pics - thanks! Hope if fixes your problem for a while.
Old 11-15-11 | 03:14 PM
Marklouis's Avatar
Marklouis
appreciate that. I could have replaced it out of pocket but I try to find the cause of these kind of issues in case it becomes more of a common issue. if it gives me another 15k-20k miles Im a happy camper.
Old 11-15-11 | 03:55 PM
caddyowner's Avatar
caddyowner
I would have had parts left over. It would have never run again. I would have hurled tools out of the garage. It's cheaper for me to drive the car to the dealer rather than having it towed there with a box of broken parts in the trunk. It's not as humorous for the dealer, though.
Old 11-17-11 | 06:45 AM
Marklouis's Avatar
Marklouis
LOL! well to be honest I did have those pesky plastic pop-rivet holders leftover - all of them broke except for 2. easily replaceable though. they just seem to serve a one time use.
Old 11-19-11 | 07:53 AM
Lynzoid's Avatar
Lynzoid
Too elaborate... Any good alternator reman place will do full reman (bearings, brushed, rectifier etc) for around 100 bucks.
JJLanders
13
03-02-22 02:40 PM
jojomanigb
11-10-18 02:47 PM
2jznosht
Performance & Maintenance
19
04-30-13 07:02 PM
cyclop123
06-22-12 10:39 PM
