squeaking sounds
also there is a settling-in period where the coilovers squeak but it should go away after a few weeks. If its been longer than a month since you put the megan's on and you still have sound, then I'd check the links.
mine started squeaking at around 10 months of use and i took it back to the shop that installed them (bc racing coilovers in this case). they said they just put on a little more lube and it went away. i drive about 25k a year.
Is there a purpose built lube for this application? If not, what do people use? I would think you would avoid petroleum based lubricants since they degrade rubber right? What to use for those DIY'rs?
mikesblkgs
Suspension and Brakes
11-28-12 09:21 AM
