Gas Smell
Old 01-27-12, 06:45 AM
Frankg2
Frankg2's Avatar
Originally Posted by ancdmd
check the fuel pressure regulators, there are two of them, one for each bank of the engine, they are behind the top of the motor near the firewall. My '02 sprung a leak in one of them and gas was shooting out the engine bay. Although yours obviously may not be leaking that much, a small leak can be hard to see but easy to smell.
Just posting to thank ancdmd... it took a while but finally the damper (pressure regulator) on the passenger side got bad enough where I can watch the gas flowing out of the top of it. Just ordered a pair of them from Sewell. I'm hoping replacing them is as easy as it appears it should be.
Thanks for solving the mystery!
Old 01-27-12, 01:37 PM
ancdmd
ancdmd's Avatar
Awesome, glad you figured out and that I could be of assistance! Should be an easy repair.
Old 11-20-14, 07:53 AM
becroach92
becroach92's Avatar
Default gas Smell
I have a 1996 lexus sc 400 and you can smell gas inside the car and outside the car even if your several feet away from the car you can smell it, it's horrible. There is no leak, what could it be? My child can't take the Smell, much less myself. Please reply asap, thanks!!!! 😁
Old 11-21-14, 09:03 PM
StanVanDam
StanVanDam's Avatar
November 20, 2014 — Lexus is recalling 422,000 model year 2007-2010 Lexus LS cars, 2006-2011 Lexus GS vehicles and 2006-2011 Lexus IS vehicles because they can catch on fire.
Lexus says the fuel delivery pipes in the engine compartment have nickel phosphate plating to protect against corrosion. Some of the pipes could have been manufactured with plating particles on the gasket seating surface where the fuel pressure sensor is installed. This can cause the sealing property of the gasket to fall apart which can cause gas to leak past the gasket.
Lexus says the recalled Lexus LS cars were manufactured May 9, 2006, to July 20, 2010; the Lexus GS vehicles were manufactured January 6, 2005, to September 10, 2010 and the Lexus IS cars were built August 30, 2005, to September 10, 2010.
The recall should begin in December 2014. Lexus dealers will clean and reseal the fuel pressure sensor mounting area. Lexus owners can contact customer service at 800-331-4331.
Source: http://www.carcomplaints.com/news/20...as-leaks.shtml
Reference: http://www-odi.nhtsa.dot.gov/acms/cs...4V647-8415.pdf
Old 10-09-15, 01:30 PM
Lexus62
Lexus62's Avatar
Default Sc430 Fuel pressure regulator
Have a raw gas smell in SC430. No local Lexus dealership, and they recommended I towed it for 300.00 to the nearest. I chose to take it to the local mechanic that works with my employer. They found it to be a fuel pressure regulator. I felt a little concern due to the guy didnt know if it was missing a screw or not. From what I can see what he is calling the FPL is a damper. So first question are they the same? Located front left driver side. On the other side of engine there is a similiar one with a screw. So I am thinking each bank has one. Have no idea.
Reluctant to take to the Toyota dealership since they told me my throttle body and water pump and thermostat needed replaced not to drive off the lot. I called Lexus they said walk away slowly. Years later the car is fine. It was a radiator cap..
So can you guys direct me in the right direction on whether FPR and damper are the same? And any photos... I know it takes about 30 mins to replace.
How difficult to replace
Old 10-09-15, 04:23 PM
gebo
gebo's Avatar
Well, I have had the exact same problem. Gasoline smell in trunk and in cabin. But the funny thing was....it only happened the Lexi I drove and filled up. I spent a lot of time and some money until one day when I had a thought.:roll eyes:
I was always trying to fill my cup to the rim. Hmmm, I wonder if I am overflowing gasoline into one to the EPA safety containers attached to my filler neck????
I quit topping off my tank on fill-ups. I only pumped gas until it clicked off first time. No rounding up to the next dollar. Gasoline smell went away in about a month. It has been gone for years. You can Paypal me whatever you feel this is worth to you.
Old 10-10-15, 04:40 AM
Lavrishevo
Lavrishevo's Avatar
When you top off the pump has an overflow as well and puts fuel back into the stations tank that you pay for. Topping off just cost you money and it is also bad for the environment. I stopped doing this years ago.
Old 12-10-15, 07:48 AM
Lexus62
Lexus62's Avatar
Only filled half way due to taking it to Lexus. They found gas around the canister. He said it was filled I questioned being it is a sealed canister, he corrected and said drips from it. They changed the gas hose and the engine light still comes on.. I was tbone a direct hit in the left rear tire and gas door,
Still dealing with the problem.
Old 12-10-15, 08:51 AM
lexusfan05
lexusfan05's Avatar
Do we have a pressurized fuel tank for these cars? I have the same smell issue in my 01 ls430 and it seems to get worse with empty tanks. I never hear the "whoosh" sound when I open the gas cap. I don't know if that's normal but I have a new gas cap from dealer and I'd expect a check engine light if gas is escaping through the cap.
I'd like to understand how our emission systems work w.r.t. gas tank. Does anyone here know?
Old 01-23-22, 06:55 AM
Thedeous25
4th Gear
Thedeous25's Avatar
So guys i have been messing with the fuel pressure dampener i pulled the fuel relay battery disconnected i took the old one out screwed it out put the new one it’s freakin worse😩! Stuck at the house on the weekend because of the **** help please!
Old 01-23-22, 04:56 PM
YODAONE
YODAONE's Avatar
So if it's worse suggests your fuel damper or sealing washers were the problem.
Did you install Lexus fuel damper and new compression washers??
How did you torque damper?
anh2lua
07-11-16 10:05 AM
Zacharias
11-23-15 10:35 AM
GRPFAN
12-11-13 12:10 PM
breakb
Performance & Maintenance
03-22-08 01:51 PM
sincityIS
07-07-07 03:22 AM
Quick Reply: Gas Smell
