Will these wheels fit my 2001 ls430
Hey guys sorry couldn't find answer by searching...
I have a 2001 ls430 stock springs etc. I see these 18x8 rims with 35mm offset. I need to make sure they will fit before I order. don't want no rubbin problems ha ha
Thanks anyone for help, here's link to rims....
http://www.amazon.com/TSW-Alloy-Whee...358137&sr=8-32
Well first off they are the wrong bolt pattern.. ls430 is 5x114
Second, the ls430 has some pretty big front brakes, the wheels have to have the proper backpad to clear big brakes
Crap
How bout these
114.3 bolt pattern and 40mm offset?
http://www.amazon.com/TSW-Alloy-Whee...4365323&sr=1-2
Thanks again
How bout these
Thanks again
Best to contact TSW or authorized dealer and get the specifics. Noting brake clearance and if sized for the Toyota/Lexus hub. The offset is conservative and will fit but the front brakes pose the priority.
BTW, 29#'s is pretty heavy for a wheel, add in a 28# tire, this will be noticeable in overall ride characteristics.
I have to agree to a point. 19s are worth it if you're upgrading and don't mind the small drop in ride comfort. 20s are a personal choice. They look nice in the right design.
You mentioned you're not lowered. A car with aftermarket wheels with a lower offset than stock isn't going to look right. Since the wheel sticks out farther than the stock wheel, it will look like you raised your car and will look like you're ready to go off-roading. A drop is almost necessary with aftermarket wheels to pull the entire look together.
Mako88
Wheels, Tires & Brakes Forum
10-01-06 11:49 AM
