Clinking sound when pressing gas pedal
Here is the noise my car makes. Each time you hear a clinking noise, I am lightly tapping the gas pedal (car is coasting). A second clinking noise can sometimes be heard when I release the pedal. For whatever reason, the sound is more clear near the console rather than down in the footwell.
http://youtu.be/Z9aXLaYUuMg
Sounds a lot different than mine. Maybe a u-joint on the driveshaft at the back of the transmission? That wouldn't really make much noise over bumpy roads though. How about a suspension part that is torqued when you throttle? Or maybe something loose with the shifter linkage? I just ordered a new front exhaust pipe, we'll see if that solves my problem.
I got my air suspension swapped out for springs and shocks in October, so maybe. It has to be something tied into the gas pedal/acceleration which stumps me.
Any of you guys figure out those noises? I'm having my exhaust heat shields removed and possibly replacing the pipe next Friday, hopefully that fixes my noise.
I just had the heat shields removed from my front exhaust pipe. The pipe didn't appear to have any holes in it. On the way home I could still hear a noise, although for some reason it didn't sound as loud, maybe it was just my perception, but the noise was definitely still there. I don't have a clue now what is causing this noise. It is getting more noticeable too at lower speeds and just normal driving. Basically a tinny, clunky, pinging noise similar to engine knock. Plus when the car has been sitting overnight and I go to start it there's a nasty metal-on-metal grinding sound that occurs right as the engine fires, it lasts for a second. Imagine if there was no oil in the motor; that's what it sounds like. This sucks.
Here's what it sounds like:
http://youtu.be/1nta5dJdHk0
I forgot the name but it's right of center near the front of the engine and you have to remove the plastic cover to see it. I think it says something like VWI actuator on it.
I have been noticing that when I start my car after it has been sitting for a while, it initially revs up to 1800rpm before settling down closer to 1200-1400rpm. When the car is warmed up, it starts under 1000 rpm. When it initially hits 1800 rpm for a second is when I hear the grinding noise.
Does anyone else's car initially rev to 1800 rpm in the mornings?
I am fairly certain the the problem is related to cleaning my throttle body. I have read and talked to others experiencing similar sounds right after cleaning it. I think the clinking sound may be the butterfly valve and the high revving sound has something to do with the TPS which is on the throttle body.
