Quick Disconnect - Battery Tender
Curious if anyone using a battery tender has installed the quick disconnect?
If you take alot of short 5 or 10 minute trips, the cold weather can be tough on my 02 UL battery so I like to use my battery tender periodically. The small ring connectors are too small to fit on the battery post. If you have connected them, where did you make the connection? Thanks.
