Purchased 05 LS 430
Hey
Congrats on the purchase looks mint. I just picked up an 05 UL black on black not too long ago as well. Are you from San Jose? If so, nice to see another LS430 around. Planning and modifications of any kind?
Rick
Rick
Javier
Congrats on your purchase. One nice thing about the LS is the suspension components are aluminum, so no rust on them...only on the steel parts.
Whether or not you use the parking sensors has no bearing on their longevity. Mine are always off, but a few times each year, I turn them on just to see if the sensors are still working. The car spent the first 4 yrs of its life in the CA and AZ deserts. Then I moved to N NM (cold) and eventhough the car is garaged, within a couple of months, two parking sensors on the DS failed (when I tested them). I tested the sensors 3 or 4 times last year and recently (nearly one year later), a different sensor failed (PS corner). So far since Nov 2009 when I bought it (21K mi), I've had the following done (currently 45K mi):
-summer 2011-front AC blower failed in 117F (luckily I have a rear blower, or I would have died from heat on the drive to the dealer!): $550 (warranty).
-nov 2011-radar cruise control ECU failure (actually, software bug, as '05 is the first year with PCS radar...common in many of the ultras...it appears after you've driven w/ cruise on for a couple hundred miles)...$800 (warranty).
-Dec 2011-two front bumper driver's side parking sensors failed...$550 (warranty).
-Feb 2012-front passenger side corner parking sensor fails...$450 (warranty).
OTOH, on my wife's 2003 LX470 we bought in Jan 06 and currently has 106K miles (no parking sensors, no tire sensors):
-Jan 06-VGRS steering ECU replaced (software bug, first year it was introduced)-$800 (warranty).
-summer 10-rear top stoplight lens cracked due to heat...common problem in AZ, but not covered by warranty...$350.
-Oct 10-steering recall (nothing wrong, just a precautionary recall by Toyota due to the recent spat of other recalls). No idea of the cost.
-Dec 11-rubber steering column-firewall boot torn (by the steering recall "fix," since it started squealing on the rubber right after the recall work)...dealer replaced it for free.
As you can see, the warranty comes in handy. In retrospect, I have to say the only "unreliable" thing on the LS430 is the parking sensors (and this would apply to all vehicles with them, meaning all Lexus vehicles in the current lineup). Also, ECU's will likely malfunction if it's the first year a new "feature" is introduced (PCS radar on the LS, VGRS steering on the LX).
Congrats on your LS.
Betty is also silver / black and has 72K miles. Only problem so far was trunk lid shocks got weak and were replaced.
UL package has all the features and I use them all. None have broken.
Google street views found Betty and took this fuzzy pix:
... This LS has so many electronic gizmos. I have turned off my parking assist and only turn it on if I need help parking. I hope by doing this my parking sensors will last a while. I noticed when I place the car in reverse my mirrors tilt down. I have placed the mirror controller in the center position so when I back up my mirrors do not tilt down and cause wear. I know as the car ages parts that are electric will go out eventually.
Why not use them until they break and if they ever do break, then shut them off and stop using them (or get them fixed). Or are you saving this car for someone in the future?
I guess I don't understand this. You don't use these functions so they won't wear out and break. But the worst thing that happens if they break is you have have to shut them off and not use them. ??
I agree with Terry... don't use something because you're afraid it might break? Do you guys buy TV and don't use the remote in fear it might break, so you get up manually to change channels?
And besides, a friend I work with has a 92 SC400 with 300k--that's right--300k miles and I made it a point to ask her tonight if she's ever had the tilt/telescoping motors go out. They haven't.
The car is old and beaten up but she's had very few issues with it. The only problem I know of is the A/C doesn't work. Still on the original engine and tranny....at 300k miles. Love it!
