Front wheels don't spin freely
Old 04-29-12, 09:28 PM
Tom58
Tom58's Avatar
Question Front wheels don't spin freely
Hi,
are the front wheels supposed to spin freely while parked?
I had a flat tire (right side) and noticed that the brake is slightly rubbing against the disc. I checked the other side (left side) and the wheel was spinning freely.
This morning I took it for a test drive, and now the left side that was spinning freely before now also slightly rubs against the brake. The right side where I used to have the flat is also rubbing against the brake just as before.
The rubbing sound is uneven, so one would almost assume that the discs are warped or is it because the car is jacked at an angel?
Brake fluid was flushed as part of 90k service 13k miles ago.
Thank you
Old 05-04-12, 06:58 AM
Tom58
Tom58's Avatar
Anybody have an idea?
Old 05-04-12, 01:16 PM
Jabberwock
Jabberwock's Avatar
My experience on the LS is that the pads do drag slightly when spinning the wheel by hand with one side jacked up. The calipers do not have return springs on them so this kind of make sense to me.
As long as the wheel isn't jammed and you don't feel real heavy friction on it in trying to turn it by hand, I think you are OK.
Old 05-05-12, 08:24 PM
V8_Fan
V8_Fan's Avatar
They drag on every car I've owned. They shouldn't drag that much. If you jack up that corner of the vehicle, you should be able to grasp the tire and turn it with your hands. The resistance is not really the pads rubbing so much as the bearing torque spec. On my LX, the torque on a lug nut exceeding about 12-20 lbs should be sufficient to turn the rotor assembly. If' the force required is like 5 lbs, your bearings are probably too loose!
Old 05-06-12, 11:42 AM
Tom58
Tom58's Avatar
Smile
Great! Thank you guys. You saved me some major headaches and a trip to the dealer.
I appreciate it.
baconRx
Automotive Care & Detailing
14
06-04-19 06:03 AM
ATLHeel350
RC F (2015-present)
02-22-17 05:54 PM
Wish
01-13-12 10:20 AM
PHXF
IS F (2008-2014)
05-03-09 10:11 PM
marcus
GS - 1st Gen (1993-1997)
03-05-03 01:54 AM
Quick Reply: Front wheels don't spin freely
