Kicker sub replacement question
I purchased the Kicker Comp 8 sub to replace the blown ML sub in my car. I've got the sub in hand. I'm going to have a friend take out/re-install the back seat but I need to know if there is any special wiring needed to install this sub to run at 8 ohm.
Here is the sub I have
http://www.crutchfield.com/S-C6FoBrN...tml?tab=review
no special wiring - some folks talk about putting a resister in the path to get to 12 ohm but that is not a good idea. Ohms are close enough that you should not have any problems. There are two terminals on the new speaker, one marked - and one marked + . Just attach to the existing two wire feed that you removed from the old OEM speaker making sure to preserve correct positive and negative polarity. If you get the polarity wrong the sub's cone will be moving inwards while the other speaker cones are being moved outwards - put simply the overall effect in most cases is loss of volume and imaging, etc.
In a car, a black wire will almost always be negative (ground). Positives can be various colors only determined by the wiring diagram/schematic.
In some two wire cables/feeds if you look closely one side of the two wire feed will have a colored stripe in the insulation, or a ridge or groove on the insulation, or a different shape (square vs. round). This is typically designated the positive (+) wire and the plain, round strand the negative (-) wire. Most standard speaker and lamp cord has this feature.
And just to keep things interesting, in typical home/house wiring, black is almost always positive - so just the opposite which can be a shocking discovery.
http://us.lexusownersclub.com/forums...howtopic=55760
where it says black +, red -
So we won't know for sure till we see the diagram like you said, so if any of the fellow members of this great forum has the stereo diagram for LS430 2005 with ML, please share it with us...
Thanks for all your help...
