Ls430 or no ls430?
Ls430 or no ls430?
Hello all, I am currently looking for a car. At first I told myself I was going to get a 2nd gen gs. Now I am considering getting a ls430. I admit I havent read all the threads on the ls430 section but I have read some. Is there anything I should watch out for? I read something about air suspension if i opt for the UL package. Then there is the rear sub behind the rear seat. I dont know anything else. Regarding maintenance, since it is the same engine in the gs430, I will be checking for the 90k service ( timing belt, water pump, etc) Any suggestions and help will be greatly appreciated. Help me know what to look out for and whether you would pick the gs430 or ls430? Thanks everyone.
Welcome and good luck with your search for a good used LS430. Tips for buying an LS and things to watch out on these cars is an often repeated topic and there are literally dozens of posts on this topic. Use the search option and you will find a couple of hours of excellent info here. Also read the FAQ thread - collected wisdom with a lot of useful side info for the perspective buyer. Forum is pretty active so if you come back with virtually any specific question your are likely to get a quick reply.
