Engine Oil Level
Engine Oil Level
On my recently purchased 2002 LS430, the engine oil level when cold reads about 1/8" above the full level. I know this sounds awfully picky, but is this a cause for worry?
________________
Steve
'02 LS430
'95 T100
'04 Mazdaspeed MX5
________________
Steve
'02 LS430
'95 T100
'04 Mazdaspeed MX5
1/²
That is a smidgen I would not worry about it. The low to high is 1 qt, so 1/8 is very lottle over
the problem with a high oil level is that the oil is high enough for the crank to come in contact with the oil. think of milk or something in a blender, it whips the liquid causing it to foam and aerate. which means less oil is available for the lubrication system. this is more of a problem for more aggressive driving though, ie on the track. so you should be fine.
what is the oil level when hot?
are you asking if a high engine oil level causes leaky seals? if so, then no i dont think so. the only thing that would/should increase oil pressure would be the oil pump. age and the cleaning detergents in oil contribute to seal leaks
