LS430 Most Miles?
Old 04-21-13, 10:12 AM
  #61
mdt525
mdt525's Avatar
04 LS Ultra 204k
Old 05-01-13, 02:40 AM
  #62
sjohnson83
sjohnson83's Avatar
Originally Posted by sjohnson83
2001 318k miles
I use the car as a taxi/livery in nyc. Purchased in 2005 with 85k miles on it.
Oil changed with 5/30 M1 every 6 months (20k miles)
Regular fuel
Trans drained and filled, and BF changed every time i change my front brake pads or about once a year.
tb/wp done for the first time 260k.
at 310k i did struts all 4 strut mounts and lower control arm bushings.
Update: 359k miles. Drivers seat foam changed with oem replacement, center armrest padding re-stuffed so leather is not taut. upper control arms, balljoints, rack bushings, and tie rod ends changed. this rides like new. No squeaks or rattles - tight as a drum. unbelievable!!
Old 05-02-13, 08:33 AM
  #63
chris81964
chris81964's Avatar
2005 UL with 173xxx miles. Purchased it in 2010 with 79xxx miles. Pretty reliable.
Old 05-02-13, 04:36 PM
  #64
warminwisc
warminwisc's Avatar
Wow just traded mine yesterday with 197k, should of kept it. New one with 63k drives way better though I am happy.
Old 05-02-13, 10:06 PM
  #65
execdoc20
execdoc20's Avatar
I have 142,000 on my 2002 LS 430. Still bulletproof and no major issues other than routine service. Plan to keep for a long time even though it is no longer my DD.
Old 05-03-13, 01:45 PM
  #66
SikHerLife
SikHerLife's Avatar
I have a 03 that just this morning hit 162,000... Thats pretty high for a Hawaii car but previous owner lived in Florida and shipped it here... I bought it last year with 151,000 miles
Old 05-03-13, 04:28 PM
  #67
Lynzoid
Lynzoid's Avatar
still recovering from THIS^^^^ post. serious impact it had on me. impressive vehicle lexus made.
Old 05-04-13, 08:18 AM
  #68
milesdf
milesdf's Avatar
2004 with 77k.
Old 05-05-13, 08:44 PM
  #69
Owngold
Owngold's Avatar
Originally Posted by tcr101
01 w/ 215k
Great! When did you replace TB?
What other repairs in the last 100k miles?
Thanks!
Old 05-06-13, 01:30 PM
  #70
reader46
reader46's Avatar
Good stuff! Where did you get the OEM foam pad for the driver's seat? I had mine replaced by a (usually pretty good) local car upholstere but the results were not so good. Still kind of flat.
Thanks!
LexusMobilMechanic (10-13-23)
Old 05-21-13, 04:32 PM
  #71
Oldguys
Oldguys's Avatar
Default 2006 Still Ticking
188K
Timing belt, battery, brakes, wheel bearings, trans fluid, rear diff. fluid, brake fluid. 19" rims get bent easily I've discovered. First owner wrecked all four. I bought the car with 90K on the clock. Black on Black.
Old 05-21-13, 08:59 PM
  #72
yeskay
yeskay's Avatar
Originally Posted by mdt525
04 LS Ultra 204k
is the air suspension still original. The air suspension UL deters me in buying one.
Old 05-22-13, 04:37 AM
  #73
warminwisc
warminwisc's Avatar
As I posted above mine is sold at 197k for a new 04 at 62k. Now a month on the new LS I feel the new LS has noticably more power, noticably shifts smoother/softer and the suspension is tighter though I have 18's now sport suspension. So if anyone is curiouse the dropoff in performance at 200k as you would suspect there for sure is some even on this overengineered car.
Having said that the old LS still shifts as smooth as most cars hoped to, has a great deal of power and pep and glad i did not pay to change the shocks/struts as they where not leaking and suspension and handling was still good, all in retrospect. It used no oil at 200k.
My only regret I could not keep 2 one for my winter car as the winters are hard on em even with all the aluminum and undercarriage covers. I have always felt as much as I wanted to drive er to see the mileage I could get 200k is alot of miles. I am glad a got a newer crisper one, but surely could have lived with the old one happily with no payment. I would have had to fix the flashin AFS light and 3 parking sensors though the rattle at start up on really hot days would bug me every time I started it, anyone else get an upper end rattle at start up on older LS's? Respectfully, Warm
Old 05-25-13, 04:30 AM
  #74
Yaff
Yaff's Avatar
Thanks!
Same here... Same question - I guess I should read to the bottom of this thread since he might have answer your question :-)
Old 05-29-13, 02:17 PM
  #75
damonbrown
damonbrown's Avatar
I think I posted on this list before, but I have 220k on mine now...2001.
Quick Reply: LS430 Most Miles?
