2001 shifting
2001 shifting
I am a new owner of a 2001 LS and have a question.
This car has a 5 speed automatic and I am getting in the habit of slipping into 4th as I approach a stop.
The transmission helps slow the auto and I put it back into drive after stopping.
I also believe shifting into 4th on long hills will help keeping it from "running away".
My question is am I hurting it by doing this?
Thanks for your opinions.
I don't think you are "hurting the gearbox" BUT - when I apply the brakes car gears down on it's own
+ IMHO with a Lexus v8 engine you really don't need to gear down on uphills - there is plenty of power under to hood to handle them...
OK, I meant on long downhills like coming down mountains and creeping over the speed limit. I slip it into 4th and it keeps it from going too fast without using the brakes.
you may not be hurting it per say but do it enough and you will eventually notice a difference in your normal every day shifting....don't use it if you don't have to i always say why put extra wear on something thats pretty much great maybe get better breaks or perhaps use yours a little more but i have never been a fan of using the transmission to control my speed.
I believe you are on the right path. Brake pads are cheap compared to transmission repairs.
I'll leave off the down-shifting and let the brains decide what it should do and when.
