04 LS430 UL Nav issue
My navigation on my 04 LS430 UL is completely off! It shows im in the middle of the mountains and jumps around to different streets. It doesnt even show im in the right city.
Is this a common problem?
Thanks all
Thanks all
You can access the trouble screen by pressing the info button on the right side of the screen while turning your parking lights on and off three times. You should be able to re-calibrate from there.
To exit the screen - press and hold the display button until the Nav screen returns.
Good luck.
Good luck.
do you have a radar detector? anything else on the windshield or dash? those things will interfere with the antenna. you could also have a bad nav ecu or an AVC-LAN issue
Good luck.
Good luck.
Menu>setup> calibration adjust> position/direction and then use cursor to adjust
Problem solved so far. I went through the options > Settings screen and found calibrated the Nav from there. Went to the corner of the street and aligned it.
Works great so far!
Thanks again for all of the help everyone!
Works great so far!
I have a 2004 LS 430 navi and having problem with touch screen.
Anyone....
