'02 Tail Lamp Failure
On my 2002 LS430, I am getting a tail lamp failure message on my dash. Problem is that this morning it is not there. It has happened 3-4 days but next day may be gone and not light up at all. Anyone have any ideas greatly appreciated.
Thanks,
Harry
Thanks,
Harry
you're the in the LS400 section, not the LS430 but anywho, you should remove the taillights and check which bulb is burnt. it's a possibility that one of the bulbs are burnt out. if none of those are, you should also check the 3rd brake light because when that bulb is burnt out, it will trigger the taillamp failure message.
I had that happen on my '02. Apparently the bulb was on its way out and worked intermittently.
I'm having a simlar issue with the small push in type bulb on the rear passenger side top left. I had a warning, it went away, came back, I seen the bulb out and replaced it, it went away for a month and just came back. I'm going to clean the contacts, replace the bulb and see what happens.
