Door garnish??
Im not exactly sure what they are called, but the squares on the bottom of the door themselves. Does any one know how they are attached? I feel like one of mine is not on as flush as the others, and even though no one else agrees with me I know what im looking at. I was wondering if they are installed via clips or tape or what so i can remove them and try to re adjust them....Any help would be appreciated.
The 4 10mm nuts go on the studs that are attached to the trim piece. One on each corner.
![](http://i46.tinypic.com/aavpdf.jpg)
![](http://i45.tinypic.com/21no6kj.jpg)
![](http://i46.tinypic.com/rbicjk.jpg)
Also if you're doing the front doors you need to take off the door panels to get to some of the nuts. A couple of them are also covered by these plastic plugs
![](https://lh5.googleusercontent.com/-U0kyV7PqeHA/UDB6uAig6OI/AAAAAAAAAco/7X1BS27h7s0/s720/20120818_193029.jpg)
1WILLY1
01-06-15 07:41 PM
