Mixing Synthetic Oil
Old 08-23-12, 03:41 PM
LS430Lexus
LS430Lexus's Avatar
Default Mixing Synthetic Oil
When my local store was out of Mobil 1, I bought some Pennzoil Ultra for my 02 UL. I use the 5 quart container and add about a 1/2 of quart. Since I have a fresh quart of Mobil 1, my question is am I doing any harm by adding a half quart of Mobil 1 to the 5 quarts of Pennzoil?
It may be a dumb question but I was taught that the only dumb question is the one not asked.
Old 08-23-12, 05:56 PM
warminwisc
warminwisc's Avatar
Not sure if Ultra is syn?
If you are this **** your car will last a long time, no worries there are blended oils all day long syn to syn is fine on occasion if needed.
Old 08-23-12, 07:12 PM
AlexusAnja
AlexusAnja's Avatar
You're fine.. there are synthetic blends which are 50/50 or 40/60 so you're fine mixing. It's not like the two won't mix and the 1/2 qt Mobil 1 will float to top.
Old 08-23-12, 07:39 PM
joedaddy1
joedaddy1's Avatar
there are people who mix their own oils on purpose.. kinda like a cocktail drug..
Old 08-23-12, 08:16 PM
RA40
Super Moderator
RA40's Avatar
No worries on mixing them.
Old 08-23-12, 09:38 PM
Dawa
Dawa's Avatar
synthetic mixed with synthetic or syn mixed with conventional.... neither will do you any harm
Old 08-24-12, 04:21 AM
sajack
sajack's Avatar
I'm a little confused. You are putting 5 1/2 quarts of oil in your 430?
Page 343 of my 2002 owner's manual states oil capacity with filter change as being 4.8 quarts.
Old 08-24-12, 05:21 AM
Jabberwock
Jabberwock's Avatar
5.5 for drain and fill oil change with filter is correct for LS430 (at least for my 2006)
Old 08-24-12, 06:23 AM
AlexusAnja
AlexusAnja's Avatar
Lexus must have changed the pan capacity,
01-03 was less than 5qt while 04-06 was 5.5.
Old 08-24-12, 07:31 AM
sajack
sajack's Avatar
I wish mfrs. would make it an even no. of quarts. These shops seldom seem to get it right, often overfill.
Lexus dealer apoarently put 5 qts. in my '02 LS430, because it reads above the full mark. Manual lists 4.8 quarts.
.2 quart is less than 1 cup full.
Old 08-24-12, 07:59 AM
AlexusAnja
AlexusAnja's Avatar
Ahh... .2 qts don't sweat it. When use to get the full jug, I would go with 5 qts and it went to middle of hash, which was fine with me. Now I get Costco case, so I put the 5.5.
Old 08-24-12, 09:17 AM
sajack
sajack's Avatar
Lexus owner's manual specifically says not to overfill. It's aggravating when technicians don't follow factory recommendations.
Old 08-24-12, 03:20 PM
LS430Lexus
LS430Lexus's Avatar
I am aware of this contradiction. The '02 owners manual on pg 343 says 4.8 qts w/ fliter change. When you put in that amount, the dipstick shows a little more than a half quart low. In addition, my recollection is that my '97 LS took more than 4.8.
I've asked a few dealer senior service techs and parts department managers. They all say the true capacity at around 5.5 to 5.6 quarts (a little more if you let it drain for a long period of time). The explanation is always the same, the owners manual capacity is incorrect and attribute this to a misprint. In addition, they say the manual is only an approximate amount. You have to check and fill according to the dipstick.
That said, I pour in the 5 qt jug, add a half of a quart and the level is always at full with 5.5 qts. Thank you for your responses.
Old 08-25-12, 10:57 AM
lextout
lextout's Avatar
Drain the penzoil out asap, they are prone to cause sludge in engines, google it and you will see
Old 08-25-12, 04:32 PM
warminwisc
warminwisc's Avatar
Even the Pennzoil Synthetic?
Quick Reply: Mixing Synthetic Oil
