Had an accident the driver airbag and seatbealt tensioner popped, I purchased a new driver airbag and had seatbealt tensioner repaired by "safetyrestored.com". Now the only item left to fix is the srs module, usually it's located under the center console, or under god forgive under the dashboard. I need to take it out to have it reset again by "safetyrestored.com".
If anybody can outline the procedure to get to the srs module I would very thankfull
2002 LS430
If the front airbag deployed, you likely need to replace front airbag sensors located near the bumper.
Unlike Hondas and other vehicles where you can jump certain pins to reset the SRS module, you have to replace the Airbag Sensor Assembly (aka SRS module) after any airbag is deployed. It is located under the center cluster and you may need to remove the centre armrest console box to access the bottom-most bolt.
