DIY : Youzealand SS Pro Kit Install / Lower Ball Joint Install (Front)
Old 02-17-16, 12:23 PM
ryanSC300lover
ryanSC300lover's Avatar
Dumb question
Is this for cars with the air suspension?
Or this for cars with coilovers?
Trying to learn the purpose of this mod
Old 02-17-16, 02:58 PM
jackies
jackies's Avatar
Google roll center adjustment, it's basically for lowered vehicles to adjust the roll center.
Old 02-17-16, 03:35 PM
ryanSC300lover
Thank you kindly
Old 02-18-16, 03:15 PM
sushiboiii
sushiboiii's Avatar
Originally Posted by ryanSC300lover
Dumb question
its mainly used for cars with coilovers. since it would require you to use more air to get back to the right height .
Old 05-10-16, 12:57 PM
yoitskenn
yoitskenn's Avatar
Is cutting the dust shield mandatory on the SS pro kit. Or is that only for 17" wheels? I'm sunning oem 18s and will be installing the SS pro kit soon. Unfortunately the pictures from the DIY are no longer showing.
Old 05-10-16, 01:30 PM
PUREADDICT
PUREADDICT's Avatar
Originally Posted by jackies
I'm getting mentally prepared to install this kit, unfortunately the pictures are gone, can anyone tell me where was C8V6C cutting the dust shield? Front/rear even? Anyone has pictures of a cut shield or can explain approximaterly what to cut?
+1 for pics pls
Old 05-11-16, 03:25 PM
sushiboiii
sushiboiii's Avatar
on youzelands site they do have a fairly straight forward instructions.
just checked not very helpful if i need to do any cutting when im installing mine ill post pics
Old 05-11-16, 03:47 PM
yoitskenn
yoitskenn's Avatar
I'll be waiting
Old 05-14-16, 02:52 AM
cerushio31
cerushio31's Avatar
I did not have to cut any of the shield as i was able to bend it in a way that it did not hit the rotor during movement. Very simple just rotate the hub/rotor after installing the SS kit and see which part needs to be bent.
Old 06-24-16, 05:20 PM
yoitskenn
yoitskenn's Avatar
What about the rears. I heard that a washer was needed on the top hat. is this true or not. I've heard both ways....yes its needed.....and no its not needed.
Old 06-27-16, 02:36 PM
yoitskenn
yoitskenn's Avatar
Dumb question....can anyone shine some light on where the rear brackets go.
Old 06-29-16, 06:49 AM
cerushio31
cerushio31's Avatar
Rear blocks mount to to bottom of the shock. They only fit one way and is pretty self explanatory once you mock it up. You need the shims otherwise you will hear a banging/clunking over small bumps in the road due to the new angle. In the instructions it states you it will damage the upper strut mounting points.
Old 07-07-16, 11:18 AM
yoitskenn
yoitskenn's Avatar
Does anyone have pictures of the rears installed? Preparing to do my rears soon and pics will be very helpful
Also clarify on spacer/ washer and the location it's supposed to go
Old 07-09-16, 04:53 PM
cerushio31
cerushio31's Avatar
All installation instructions are listed on their website
http://www.youzealand.net/parts/ss/install/
Blkexcoupe
02-13-23 04:38 AM
Ls460kidd
10-31-17 01:23 PM
gobears
05-30-07 04:12 PM
Quick Reply: DIY : Youzealand SS Pro Kit Install / Lower Ball Joint Install (Front)
