Heater blowing cold
Old 11-07-12, 09:49 AM
Lynzoid
Lynzoid's Avatar
It's possible in case OP have system with radiator cap. I don't. I have an expansion (unpressurised!) tank system on my 2001 and there's no radiator caps employed...
Old 11-07-12, 11:43 AM
dlap
dlap's Avatar
Thanks to all of u. I will make an appointment with the shop for test.
Old 11-10-16, 09:43 PM
tallcaguy
tallcaguy's Avatar
Have some heat when set at max. Not much at lower settings. I've just had the coolant drained and replaced. Tech says it looked fine. New radiator cap. Pressure tested system and it's fine. Heat valve (bulkhead placement) arm moves to correct max hot and max cold settings.AC works perfectly (fans blow at low/medium/high settings). I suppose it could be a clogged heater core or defective temp sensor. Suggests much appreciated!
Old 12-18-16, 02:48 PM
pierreluv
pierreluv's Avatar
I'm having the same problem
Old 12-18-16, 06:10 PM
rkw77080
rkw77080's Avatar
Please take a look at Post #3 on the link below for some troubleshooting steps...
https://www.clublexus.com/forums/ls-...goes-cold.html
Old 12-19-16, 06:12 AM
Tom57
Tom57's Avatar
The thermostat may be stuck open or the rubber seal around the thermostat valve (which seals off colder coolant from radiator) is split which prevents the engine from getting up to full operating temperature. Both the t-stat and seal are easily replaced.
There could be an air lock in the coolant system around the engine block / heater core. Does the temperature gauge get up to full operating temp? There is a weep hole in the t-stat to allow coolant to slowly refill the block and heater core.
Old 12-20-16, 05:48 PM
pierreluv
pierreluv's Avatar
I took mine to the dealership repair cost was 40 bucks it was an air pocket like someone said
Old 12-23-16, 06:37 PM
tallcaguy
tallcaguy's Avatar
Yes temperature goes to full operating (mid gauge).
Old 12-24-16, 09:32 AM
Tom57
Tom57's Avatar
Take it back to the tech who did the work and have him fix it. You shouldn't have a heat issue after coolant exchange when you didn't have the issue before the work.
Old 11-29-18, 03:25 PM
Nphoops
Nphoops's Avatar
My 2003 base LS430 blows fairly cold air on idle, warms up slightly when driving. Temp gauge stays very near the low end, never toward the middle like normal, even when driving for 30 minutes. I'm going for t-stat change first (cheapest,first, right?).
BTW, I've got 249,000 miles on her. Bought it with 119,000 and haven't changed t-stat yet.
Old 12-05-18, 12:59 PM
SpringerPo
SpringerPo's Avatar
It's just recently that our temps in SoCal have dropped to the point of needing heat in the car. My wife came in last evening with an "A/C only, no heat" complaint, thus I've found this thread.
The low coolant theory rings truest in my ears, so that's my first direction. It's raining today, so won't get to it until Friday, but I'll report back if I find something.
thomashmc1
12-18-17 07:29 PM
river
RX - 1st Gen (1999-2003)
02-15-16 06:35 PM
mfb496
12-13-12 02:40 PM
qwijibo419
08-26-10 11:50 PM
Lexusnyc
SC- 1st Gen (1992-2000)
05-14-03 07:31 PM
Quick Reply: Heater blowing cold
