LS 430 Timing Belt replacement
Old 06-03-15, 10:49 AM
  #76
Tom57
Tom57's Avatar
Originally Posted by Rexor20
I'm in Des Plaines but the mechanic works out of his house in Antioch which is just south of the Wisconsin border.
I was told that he is an ex Lexus certified tech and has a lift/shop setup in a separate garage on his property.
Oh, nice. I'm in the western burbs of Chicago.
Old 06-03-15, 12:59 PM
  #77
Rexor20
Rexor20's Avatar
I'll probably be going in the next month or so. Keep you all updated since I know this is a ridiculously overpriced job at the dealer.
Old 06-03-15, 04:15 PM
  #78
StanVanDam
StanVanDam's Avatar
To DIY, see http://www.shastaanesthesia.com/Lexus/Page1.html for the writeup and as mentioned above, watch the video at https://www.youtube.com/watch?v=dCTGHurWA1c
AISIN Part # TKT021 comes with the Hydraulic Tensioner
AISIN Part # TKT001 does not come with the Hydraulic Tensioner
I've read in several places both kits contain the exact same parts as OEM, the only difference is in the packaging.
Old 04-24-16, 05:28 AM
  #79
osoali
osoali's Avatar
Originally Posted by ForrestY33
Alas, another great timing belt debate. The challenge with taking advice from anyone (including myself) on this forum is that you're asking advice from the people who have the LEAST direct experience with a timing belt failure. Go find the people who have actually had a timing belt fail on a LS430 and ask his/her opinion. Wait a second...you can't find a single one??? That's because they probably don't exist because timing belts just don't really fail very often, no matter how old or how many miles they have.
If you ask around, what you will find out is a lot more members (especially relative to how many have had a timing belt failure) who have gone way past the recommended 90K miles and have yet to see a single failure.
True, the LS430 has an interference engine, but it also has hydraulic tensioners, which in simple terms, keeps the timing belt properly tensioned thus greatly reducing the probability of failure. I think you should have no issue waiting until at least 90K to change your timing belt. I'm personally going on 98K on a '04 and don't lose any sleep over it. Maybe I'll think about it at 120K.
I agree 100%. Mine is a 2006 ls430 and i have 135km on it. I checked the belt a month ago and looks brand new. I might change it at 150,000. Plus the engine for ls430 is so cheap (since they never fail). Yo can buy a good used one for less than a 1000.00 . I take the chance.
Old 05-15-16, 03:37 AM
  #80
TFBTRADE
TFBTRADE's Avatar
Default Haven't paid much attention to transmission. Now at 424,000
Haven't paid much attention to transmission. Car now AF 424,000 miles
Originally Posted by Lavrishevo
Your are a brave man TFB. That's awesome that you are at nearly 400,000 miles. The 400 and the 430 are in my opinion the most reliable cars ever made. I assume you do tons of highway miles, which is easier on the engine. How about the transmission? Have you been servicing it with new fluid?
Old 05-17-16, 10:40 PM
  #81
dicer
dicer's Avatar
Wow, interesting read here.
I have seen a 144 K timing belt failure on a 90 LS400 some years ago. I have seen lots of timing belt failures on the little 4 cylinder Toyotas, and older VW inline 4's, Subaru's too. Some of the failures were from a rotten belt and other causes like oil soaked as well as bearing seizure on guide / idler pulleys or pumps. So all this stuff about don't worry about it, could be an expensive mistake, that makes what ever a dealer or shop charges look cheap.
Old 07-19-20, 09:00 AM
  #82
jayface
jayface's Avatar
Default Original timing belt
I recently purchased a used 05 RX 330 With 172,000 miles on it and I’m the 3rd owner. The car has over 20 car fax services reported but there was no mention of TB. So I took it to my mechanic and he said that I lucked out with a great car, other than some cosmetic stuff the car is great. But he said upon inspection couldn’t find a TB sticker and he highly recommended changing it. I didn’t hesitate and told him to do it. After it was over with he kept the belt to show me what it looked like. While i can say without a doubt you can go past 90k ok the belts. This RX was the original timing belt at 15 year and 172,000 miles. It was visibly warped and cracked however. I personally would of changed it at 90 cause that’s the person I am but I’m happy to know that if you can’t do it right at 90k you won’t break down or mess your car up if you wait a bit longer. They’re all amazing cars and I don’t know why anyone would drive anything else ha ha I’m heading to the dealer today to look at an 04 LS that has 56k and one owner. And I’m STOKED
Old 06-17-21, 07:51 AM
  #83
RA092822
1st Gear
RA092822's Avatar
I thought all LS's came with timing chains. I had a Lexus LS430 2001 and I never in it's 270K miles that I owned it for have ever replaced the timing belt. It never failed on me, Lexus is absolutely amazing lol.
Old 06-17-21, 09:37 AM
  #84
Uh, change it ASAP. But yes I'm not surprised at all that you have attained that mileage on the first TB.
I changed at 102k and asked for old belt, thing looked almost brand new. I'm definitely waiting longer for next change.
Old 06-17-21, 01:36 PM
  #85
ls430w140
ls430w140's Avatar
That’s the RED alert/flag for your car, change it ASAP to prevent engine damage. Have you done any other maintenance so far? How often do you change engine oil?
430SLOwner
08-17-19 02:31 PM
pienomiko
Maintenance
03-10-09 06:48 PM
dude74
14
04-01-02 10:29 PM
Quick Reply: LS 430 Timing Belt replacement
