About to go to the stealership (Toyota)
i had a toyota dealer tell me that it would cost 135 dollars to power flush and fill the coolant in my 86 mr2 and 79 to do a drain and fill.i talked to there master tech and he said they dont have a machine for a coolant change and they only drain and fill.
moral of this is if you dont talk to there master tech you will pay for a service they dont offer.
Oh and btw i never got a call this morning.. just called and the guy didnt know anything about it just that it says not finished. Nice.
Having a few issues with my 2002 LS430.
Somethings up with the handling.. I get a vibration through the steering wheel about 45mph and it gets worse the higher I go. I seem to have to fight with the steering wheel to keep it straight.
Im hoping its just wheel balance but it might be a suspension part gone bad![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I also need the rear diff fluid changed (I supply fluid)
Trans fluid has never been flushed (140k) thinking about having that done.
Also a check engine for P0430.
How much do you think they will rape me at the dealership?
Ended up getting quoted $4500 to replace the whole exhaust I believe or maybe just the cats. Yeah that wont be happening. The P0430 hasnt even come back on.
Trans fluid was flushed, diff fluid changed, wheels balanced, and tire stem replaced. Also they repaired #4 ignition wire that was causing a P1315.
Car runs great and no more vibration![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Was going to be almost $400 but since I had to wait almost 4 days they knocked it down to just under $300.
OMAHA
08-02-14 06:10 PM
