LS430 Wheel Fitment Reference Guide
Old 05-09-18, 10:57 AM
  #31
FortuneLS
FortuneLS's Avatar
Originally Posted by onthelo
So with this setup is it for static fitment or bagged? The mentioned specs with +30 will be helpful but for the rear depending on fitment will most likely need to shave the rear lip for clearance. The disk should be good for the LS caliper size and the widths also depend on tire size. Typical size for this type of fitment is 225/35 front and 245/35 rear but it is very stretched
its factory air with datasystems
the high disk for the 9.0J is +32 and for the 9.5J is +40
for the mid disk 10.5J is +34
so should i do 9.0 or 9.5 in the front?
Tires id like to run at least 235 and 255
Old 05-09-18, 01:43 PM
  #32
onthelo
onthelo's Avatar
IMO if you want to run that tire size with out too much pull prob going to want to stay at the 9.0 front and something like a 10.0 rear. Pretty sure that is the tire size of Brownmann's LS but he does run the 9.5 and 10.5 around +26 front/ +30 rear I believe but the tires do pull. I run my setup 225/245 same wheel width but they stretch hard and my offset poke quite a bit at ride height. I can only speak from my experience and I am unsure on the +40 for 9.5" and +34 on the 10.5 I know for sure it will bring the wheel set inward towards the body just not sure how much clearance you will have there.
Old 05-18-18, 06:48 PM
  #33
FortuneLS
FortuneLS's Avatar
I ended up going with Ordens, 19x9.5 +26 standard disc and 19x10.5 +25 low disc with probably 235/35 and 265/30 tires, now the waitimg game begins... 12-18 weeks is going to be brutal...
Old 05-25-18, 04:33 PM
  #34
UCF30_SD
UCF30_SD's Avatar
You should be fine with that setup, however that +25 in the rear your gonna need to either pull your quarters or run lots of camber. I have Bugels and i'm doing 20x9.5 +25 and 10.5 +27. Front and rear fenders rolled flat running -1.8 degrees of camber all around.
Old 06-01-18, 01:17 PM
  #35
FortuneLS
FortuneLS's Avatar
the OP is running 19x11 Bazerias at +24 in the rear with just a roll, so i should be good with 19x10.5s +25 in the rear with just a roll as well i would think.
im thinking of running 30 series tires all around, 245/30 front and 265/30 rear... thoughts?
Old 06-04-18, 02:04 PM
  #36
onthelo
onthelo's Avatar
10.5 +25 on the rear with a roll will not tuck or clear the quarter panel imo just from experience on mine I had to shave the quarter panel all the way flush practically and pull about 3/4" to get the fitment. Also running a 245/35 to get the stretch as well to help the tire from hitting the lip.
Old 06-06-18, 02:08 PM
  #37
UCF30_SD
UCF30_SD's Avatar
It also depends on the faces. what works for one wheel, may not work for another. I believe DPKDavid is running something similar to what you have in the rears but in a 20". He needed to do work to make them fit.
Old 06-07-18, 06:48 AM
  #38
onthelo
onthelo's Avatar
Again just going to stress this for anyone looking to fit a rear wheel with similar size and offset 20x10.5 +25 (also depend on face such as UCF30_SD had mentioned) will need fender work even if not on air because of suspension travel. If you need pics I can provide to help. PM me separately.
Old 06-08-18, 01:32 AM
  #39
UCF30_SD
UCF30_SD's Avatar
I've found the sweet spot for minimal camber, bodywork is 10.5 et +30 on stock camber arms if your looking to tuck wheels.
Old 06-08-18, 07:43 AM
  #40
FortuneLS
FortuneLS's Avatar
im not running 20s
i ordered Leon Hardiritt Orden, 19x9.5 +26 standard disk front, and 19x10.5 +25 low disk rear.
I plan to roll the rears, and run a 5mm spacer up front to clear the brakes.
Old 06-08-18, 08:14 AM
  #41
onthelo
onthelo's Avatar
im not running 20s
That's not the point though my fellow Cl friend, here is my point 20" or 19" it will come down to overall tire diameter and also if you do not run a stretch to pull the tire away from the outer lip. Can you tell me the overall tire diameter for the rear that you will be running just trying to help save you some headache? Just as some advise the rears usually do not get rolled on the LS the metal is double layer metal and with the square insert for the trim, once that is removed if you attempt a roll it may dimple or "bacon" the outer quarter. Not totally impossible but just search it out and you will see most guys shave the rear lip but then you can run into metal separation just my two cents. so either way there is a challenge to do it clean with such an aggressive offset. Also a pull should be required to tuck these unless the overall tire diameter is less then 26.8" the reason being at that overall diameter with that offset the wheel/tire lands outside the body line I can show you if you like. Others here such as DPK have done the same rear fender work as I have and quite a few others so just sharing the first hand experience but again I understand this is with 20" and you have the 19" so possibly it will just fall into place with the lower profile tire and 1" smaller diameter wheel. I love your wheel choice and am excited to see when they come in!! Keep us posted!!
The following 2 users liked this post by onthelo:
FortuneLS (06-08-18), PNWLS430 (12-30-20)
Old 06-08-18, 08:54 AM
  #42
FortuneLS
FortuneLS's Avatar
I appreciate the input and feedback, i was just trying to get it across that i was running a 19” wheel and not a 20”. I chose to go the 19” route specifically because after doing some research i learned you could run a more aggressive offset with less bodywork than running a 20”. I eventually will probably step lip them up to a 20” when im ready to do full on body work and a repaint when i order my kit, but for right now i just wanted as aggressive a setup as i could fit without doing the serious body work. Plus living in iowa my resources for doing the kind of bodywork required for cutting/shaving fenders is limited. Nobody around here understands what im trying to do basically, lol! im not sure the overall diameter, but i was planning on running a 245/30/19 in the front and a 265/30/19 in the back. The OP is running a 35 series, with 225/255 so i wanted to try to avoid a big stretch by going with a shorter sidewall. I ran 245/35/19 on my 9.5” wide +25 squared set up on my AWD 3GS with just a rear fender roll, and thats about as big of a stretch as i want to go if possible... Im also planning on running fully adjustable control arms, and 1.5° or 2° Negative camber. This car isnt my daily, more of my toy.
Im in week 2 of the 12-18 week wait for my Ordens to be built and shipped😩 the wait suuuuuucks!
Old 06-08-18, 09:28 AM
  #43
FortuneLS
FortuneLS's Avatar
Was just playing with a wheel and tire fitment calculator at wheel-size.com, and according to it, with a 245/35/19 up front its 25” 25/32nds overall diameter. With a 265/30/19 in the back its a 25” 9/32nds overall diameter.
Old 06-08-18, 10:29 AM
  #44
jayclapp
jayclapp's Avatar
That would give a 1.98% error in the speedometer between the two tire sizes.
Old 06-08-18, 10:36 AM
  #45
FortuneLS
FortuneLS's Avatar
is this bad? or in the acceptable range...
Quick Reply: LS430 Wheel Fitment Reference Guide
