Moonroof - how many drain tubes are there?
Hi guys,
I needed to clean my moonroof drain tubes cause my car leaked some water after a heavy rain so I bought some cable that fitted nicely into the two drain holes I found when I opened the moonroof - one on each front side corners (left and right)...
Well, they are cleaned now but I am wondering is it only those two drain tubes that are there?
Isn't there some more maybe on the back side where I'm unable to see or?
Thanks
Thanks
There are 4 tubes, 2 at the front and 2 difficult to see and get at toward the rear on the sunroof.
I had a Ls400 97 plate and cleaned them, i used the wire that is often used to hold up net curtains, firm and flexible at the same time, just the size for the hole as well.
My 2002 ES300 does not have the problem. I read all the forum info and will attempt to blow out the holes (if I can find them)
Thanks all
Thanks all
tyncobb
17
05-24-20 04:43 PM
whokidd
11-19-13 12:45 PM
winner155
12-09-12 10:43 AM
