2002 ls430 takes bumps badly.
Old 03-04-13 | 12:52 PM
Simonio's Avatar
Simonio
Default 2002 ls430 takes bumps badly.
what could be wrong with my 2002 ls430 suspension? it takes bumps badly
Old 03-04-13 | 01:59 PM
ls430lover's Avatar
ls430lover
Default hi some food for thought
most lexus dealers especially j and m lexus in florida and others will do a free check over the car. with the suspension some of the things to consider when evaluating a ride issue are below
1) check the shock/struts to see if they are leaking
2) ball joints to make sure no movement in wheel while inspecting
3) strut arm bushings need to be replaced between 80 and 100,000 miles this is more for a noise while breaking and left to right movement while driving,
4) inspect tires to make sure the care has the right pressure my 2002 with 35 lbs rides like a rock and at 32 its much better
5) have the alignment checked, if the cast and camber are way off and the tire is not meeting the road properly it will effect ride quality.
6) pray you don't have the air suspension because its a fortune for those air shocks
safe driving
FatherTo1
09-17-16 08:44 AM
MX5
01-06-15 10:03 PM
Nixsun79
08-13-11 08:32 PM
owbatm
03-24-10 02:09 PM
