Jack points question for DIYers
Anyone know if there's an adaptor for a standard floor jack saddle for the jack points on the LS?.
The jack points have vertical flanges, I assume as a safety feature to keep the factory jack from slipping, as its saddle has a slot to fit the flange. For you DYIers not using a lift, are you using the factory jack or a block of wood w/ a floor jack, or something else? If there's an adapter, I couldn't find it. A plain flat saddle bends the flange, and then you have to bend it back to use it w/the factory jack, and the strees can't be good for the flange. Jacking under frame where a lift would reach it is pretty hard, as the frame is pretty far inboard, but that looks like the only way to do it.
Any thoughts welcome. Thanks.
a lot of people have had great success with using a piece of wood with a slit in it, but that just
isnt for me.
my approach was to take a piece of square tubing, and cut a slit in it (pretty much mimic the scissor jack)
the thicker the (gauge of the) square tubing, the better, obviously.
i think 13 gauge would do quite nicely.
![](https://t0.gstatic.com/shopping?q=tbn:ANd9GcQbK70h1Ygzh1zDOvsS1s2OwgnUkMvqQstLonZi1ZgkZI779gQRpI742eo4gEb0w_6ubK9URw&usqp=CAc)
i think i got 16 gauge at home depot, but i did not like how thin it was. i also wasnt able to cut it because once i had it secured in my vice, it put horizontal tension on the metal and would not allow me to cut a slit in the top easily because the saw blade kept binding.
thats when i went to a metal supply place and found some 13 guage bar stock that looks to be more than efficient. i never got around to doing it though, as i have 3 other project cars that need more love.
anyways, a 1 to 1.5" wide by 2" long piece of square tubing should suffice both to put on the pinch weld for jacking OR stand purposes.
isnt for me.
I use the center support on the front and the rear diff as my jack points per the owners manual. Also if you must use the pinch points for jacking I recommend a Jackjaw from FIGs
http://shopfigs.com/v1/index.php?rou...product_id=188
i use the front and rear supports as stated above.i use a low profile jack.if you dont have a low profile jack you can jack up the front left or right side using the jack point behind the tire and put a jack stand under the front support bean then use you jack to lift the front at the middle jack point.
BoyOhBoy
05-27-14 11:29 PM
