Help me diagnose starting problem *VIDEO*
'02 140k miles, developed this issue yesterday, when the starter is engaged with the ignition there's a click and then a delay before it starts to crank the motor, and it stumbles to fire up. The battery is a Toyota battery and is less than two years old, I cleaned the terminals and cable ends and the problem persists. Could it be the contacts and plunger? Here's a video with four attempts at starting the car, the fourth attempt is the worst. Notice I do not turn the key back to the run position until after the motor fires up.
