Idle Becomes Rougher When AC Is Turned Off?
It's clear when I shut the AC off, the idle becomes rougher. It's not extreme, but you can clearly feel more vibrations through the steering wheel and seat. It's not throwing any codes.
I cleaned the throttle body a few months ago, so I don't think the issue is there. My first guess is the IAC valve, but wanted to see if anyone had a similar issue?
Thanks
Thanks
Ok thats a little strange. It is usually the exact opposite. A/C kicks on, idle drops, and vibrations increase. That is a situation that would make me lean toward and IAC valve. Those 430's usually run so incredibly smooth, I'm thinking you might have something else going on. How many miles?, Changed your PCV valve? tune up recently?
LexDymond
12-10-10 07:25 AM
