Lag in driving
Lag in driving
Hey y'all,
Today I think I might have a mechanical problem, or it might just be me over hearing and over feeling some noises.
I just want to know if some one has experienced this before just to be able to know if it is serious and it is really something I should look after, or know that it's my super hearing powers are just overreacting.
So, the problem is, the car drives perfect. with 125,xxx miles. Everything is very smooth. Except that I feel that the car is kind of lagging or cutting off a little bit when I apply 1/4 throttle power. It's alright if I give full throttle or middle throttle. But I'm feeling this weird lag at about 1/4 power.
It might be some gas filter or something. Have no idea. I appreciate your help guys. Let this awesome forum forever live!
tough to say, however i've noticed something similar in mine. I believe its working as designed, at least in my case...think its just part of the Lexus LS design to have a slight lag in throttle response at less pressure. This isn't a sports car after all. You might also have a dirty throttle body....ever been cleaned??
the other thing you might experiment with is RPM...in other words, manually place the car in a lower gear, get the speed and RPMs up, then apply the 1/4 throttle to check responsiveness then. If it responds fine at higher RPM with same 1/4 throttle then the "lag" might have something to do with where you're at on the power curve/torque curve. 1500rpm lugging around town is just not going to feel as snappy as say 2500rpm...
A couple of suggestions to try. First make sure you are running clean air filter and also go in and clean the MAF and throttle body every 6 months or so. When these are clean the engine in the LS should idle and run smooth as silk and pull like a GE jet turbine. Disconnect the battery before you clean MAF and TB and reconnect after, it is about a 30 minute job and it is better for ECM to be off when you manipulate the TB plate open to clean it. Once you reconnect battery after diconnect of approx 30 min the ECM will relearn your driving style and set engine and trans characteristics to accommodate.
to the OP, its probably in your head , sometimes when your Pu$$y footing the throttle, like I do a lot of times, the car feels like its lagging, sometimes its in the process of gearing down, or up, and its taking a second to kick in.
Don't worry about it , but yea make sure your air filter is clean and the other things they mentioned, that wont hurt at all.
Thanks for the links, and all the help.
I took out the MAF and placed it in a ziploc bag full of Acetone, or nail polish. Just full enough to cover the whole sensor.
Gave it a good shake, then I took it out and just touched it up with some Q-tips. Then let it dry for 10 minutes and installed it back.
To be honest I didn't expect this much or big of a difference. The car feels new. It responds very differently. In a good way. The MAF was ridiculously dirty.
I advice anyone who just got a used car to do a MAF cleaning session. The car will definitely feel different.
good to know man
I have this lagging thing too , it happens on the very low end when im trying to baby the car, it seems to get cought up between gears or something, ive heard others complain aboiut this too, I think its just how the tranny is designed.
when I drive the car properly and give it a healthy amount of gas , I don't notice it at all
