2002 ls 430 codes P134b & P1349 VSC & Check engine light
134 is O2 sensor bank 1 sensor 1
1349 is a vvt problem I believe. Might need to look into that more closely. Dirty oil control valve is mentioned in some post. Also, the vvt controller assembly could have gone bad.
https://www.clublexus.com/forums/sho...e=5&styleid=13
Are you sure about p134b? might be 1346? http://engine-codes.com/p1346_lexus.html
The other is at the following link
Link: http://engine-codes.com/p1349_lexus.html
Randy250
12-31-14 07:40 AM
