Tranny won't go above 2nd gear
But only intermittently. Most of the time it operates normally. Anyone know if this could be something cheap and easy to fix or is it probably a sign the transmission is crashing? Car has 268,000 miles and has been regularly serviced.
Not many transmission failures reported on these cars but with 260k it's hard to say. I'd suggest having shift solenoid and valve body checked first. Any debris in the pan or fluid?
Paging Craigster, did you find a solution to your transmission issue? My 2004 is showing the same symptoms; but with only 105K miles. Would appreciate any feedback or info you have.
Thanks in advance.
Thanks in advance.
