2002 ls 430 front bushings
I'm pretty sure I need my front bushings replaced, and was quoted about $600. Has anyone else had their front bushings replaced, and if so, what did you pay? I hope this isn't to personal.
The most common to go are caster arms, lower and upper control arms, and the 3 motor mounts. We often refer to the rear one as the transmission mount but Lexus calls it a motor mount. Both my caster arms were replaced by the previous owner. I've done the rear motor mount and my steering rack bushings. I will be doing my front two before too long. They don't look bad or cracked but after about 100k it's pretty much recommended to go ahead and replace them. Don't go aftermarket on the motor mounts.
Roca, in my research from the LS400 too, is the best aftermarket option. They are urethane like oem vs polyurethane like many others. Poyl's will ruin the ride quality.
bicol-ini
06-25-07 07:17 AM
