ebay timing belt kit
Hello, I have 140,000 on my recently bought 2002 ls 430, and after reading some of the posts, I figured I'd have the timing belt and the other parts replaced. I was quoted $677 to replace tb and water pump, but I wasn't sure if the other parts like the tensioner pulley was included. I no longer work on my vehicles, so exactly what parts should I have replaced? And, like some have mentioned, the Aisin kit is really OEM and good to go?
Aisin & Mitsuboshi IS the factory Lexus parts so paying more for the same thing is sort of dumb. Often youre paying for the Toyota packaging. I can tell you the vendor of every Lexus/Toyota parts and that kit seems to contain all of the OE parts. I tensioners pulley and idlers are in deed Koyo for OEM and Belts are Mitsuboshi, WP is Aisin, can seals should be NOK, and tensioner assy is NTN.
It is REALLY hard to get over the mental skepticism, I just went thru the same thing, I absolutely only want OEM parts on my car.
I can't get over it until I have both the Aisin parts and OEM parts from a dealer to compare them with my own eyes.
I returned the OEM parts![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Like I just said, the Aisin's box is actually much nicer then the OEM box
Arcturus
03-28-16 09:03 PM
canucklehe
01-23-13 09:06 PM
sorka
Performance & Maintenance
07-14-08 06:54 PM
