2002 430 thermostat
i'm replacing my tb and other parts, but I couldn't find the exact thermostat. I have a 2002 ls 430. I tried to find it through rockauto, but couldn't.
It's worth paying extra to go OEM in this case, you're talking about something like $7 more, and the above referenced Stant Thermostat is 180 degrees, the factory one is 190 degrees AFAIK.
On modern cars, the old trick of putting in a lower temp thermostat for it to run a bit cooler is usually a bad idea, the ECM thinks the car is still cold and remains in a closed loop operation, running richer.
I'm not someone that thinks you need to run to the dealer for every part, but I think it's a small premium and not worth getting an aftermarket with the wrong specs.
Also, a thermostat made in Japan versus say Mexico or China? I know where I'd bet my money.
Even still, I personally would rather take my chances with a factory one. I had a non-OEM thermostat fail on me. It's worth the small premium not to have that headache.
Part number 9091603100 pulls up a stat with an opening temp of 180 and fully open temp of 203
Also price is like $17 for the stat from Sewell Lexus. Dont tell me you drive a LS430 but are pinching pennies where you need to find an aftermarket part thats cheaper then OEM when its a $17 part.
thanks for the responses, but rockauto and sewell are oem parts. I wasn't being cheap; I simply kept seeing both 180 and 190 thermos, and couldn't find info explaining which is needed. so, is the 180 the correct one?
Try looking online at parts(dot)com. They have the part and all their stuff is OEM - at least all the stuff I've ordered. Their price and service is top notch. It takes a while to dig through the menus but they have everything (really).
In most cases, a Lexus part number is the same as a Toyota part number. Whereas, the Toyota part will be far cheaper than a Lexus part, even tho, they are exactly the same. Trust me.
