Purchasing an 04 LS430: Water Pump / Timing Belt Q
The car has only 68000mi and we'll kept. The carfax shows the timing belt was replaced at 60000mi. The dealer informed me the water pump would typically be replaced as well. Is this true? The carfax does not show it.
Thanks everyone... I've spent the last week browsing this site and learned a lot about this car and love it!
Thank you
Dealers may not replace the water pump at that low of mileage unless it was leaking... Usually the TB is done at 90K not at your 60K. I would bet the pump was not done unless the owner specifically stated to replace it.
This is the same dealer where the car was initially sold at and serviced so that should make it a lot easier. I did ask for service records but they printed the carfax I already had. Another question to piggy back off is can I ask how much they paid for the car as a trade in? Will they provid and an invoice for it?
Thank you
Thank you
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Go to My Lexus, register, add the vin number then check service history. Any service performed by a Lexus dealer should be displayed.
Going back to the dealer tonight to see if we can come to an agreement on price
I appreciate all the feedback on this car. I hope I can return the favor down the road when I have some experience with this car.
I have been lurking on this site all this week trying to research this car inside out and I have been more than pleased. This is the right car for me...now it is just about the price.
I have attached the last part of the service history and was wondering if anyone saw anything out of order or something I should watch out for before I pull the trigger and buy this car???
Thank you everyone!
Thank you everyone!
This is a UL with the air suspension right? That is really the only weak spot on the UL's. Eventually, the air shocks will fail and to replace new they run around $1100 each before labor and alignment. You can swap the whole suspension out for the standard coil / shock for about $1500 - $2000. I'm at 111k on my 04 UL without any issues.
From searching these forums, it's apparently typical for the ML to have them
You're going to pay up for a UL... that's for sure... and pay more from a dealer... so two strikes on the high side.
But then, the UL with all the extra bells and whistles may be what you're looking for. I know many of us live happily with less![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
You need to arrive at the price you're happy with..
