DIY license plate cover
Old 03-23-14, 09:40 AM
dapimpee
dapimpee's Avatar
Default DIY license plate cover
Found a piece of plexiglass that was blue painted. Scrap the paint, cut it and turn it into the license plate cover.
Attached Thumbnails DIY license plate cover-img_1325.jpg   DIY license plate cover-img_1324.jpg
Old 03-23-14, 02:30 PM
LiCelsior
Retired
LiCelsior's Avatar
not bad..smooth out the edges and make it crystal clear and its a winner.
Old 03-23-14, 02:59 PM
1WILLY1
1WILLY1's Avatar
needs some detail work , but good start
Old 03-23-14, 03:19 PM
jayclapp
jayclapp's Avatar
Just one question. Why?
Old 03-23-14, 03:25 PM
dapimpee
dapimpee's Avatar
yes it' still raw. . Do you guys know what solution i can use to polish out the scratch?
Old 03-23-14, 03:31 PM
1WILLY1
1WILLY1's Avatar
you would literally need to wetsand both sides with fine sandpaper, and then polish it out or clear coat it
not to be negative but in this case it is much easier to just buy one, the sandpaper alone would be more then the cost of a new one
Old 03-23-14, 03:57 PM
SuperCoupe400
SuperCoupe400's Avatar
I love DIY projects as much as the next guy, but i've gotta piggy-back on jayclapp's comment here. If it's not curved backwards at the edges (to form a seal against the license plate), then all it will do is let dirt back behind it and thus make it harder to clean and dry the plate.
Old 03-23-14, 06:06 PM
grims
grims's Avatar
hi im new here
so i cant do a lot yet
and i dont speel weel
so here is a neat trick
if that is plexiglass
take a torch, the kind you heat up water pipes with, preferably propane but map gas works too.
and pass it over the edges
it will turn them smooth and shiny, it will look like someone made it just for you
i used to make subwoofer boxes, you know the kind that rattle the car next to you, for show cars and thats how i would prep the plexi to look perfect.
this really really does not work on lexan just so you know.
i learned that the old fashioned way. then i put the fire out.
Old 03-23-14, 06:51 PM
AlexusAnja
AlexusAnja's Avatar
Some states, covers are illegal and will get a ticket. The cover could however be useful against red light cameras if it casts a glare...
Old 03-23-14, 06:56 PM
SuperCoupe400
...Well, not to mention, there IS a special coating you can spray on to your plate cover to make the plate unreadable to traffic light cameras.
Old 03-24-14, 09:32 AM
ancdmd
ancdmd's Avatar
intrinsic
12
11-02-15 12:46 PM
EyesOnly
07-27-07 08:14 PM
fred430
07-08-07 09:38 PM
Black Ten
03-08-06 02:34 PM
DaveJ
06-08-05 11:03 AM
Quick Reply: DIY license plate cover
