01 LS 430 A/C Problems
My A/C blows cold When it feels Like it, The Clutch turns even when its not Blowing cold, But the gauges read 75 lbs on low side and 100 on high side, which makes me think the compressor is not Compressing , then the next time you get in it, It will freeze you out for a while the it stops working again, Once I got mad Took off real fast and it started working again,, Any Ideas Before I buy a new Compressor, ????
B4 you get a new compressor, and a new receiver/dryer, and a few pounds of R134a, and borrow a vacuum pump, use your set of gauges to diagnose problem.
here's a start: http://www.examiner.com/article/air-...ge-diagnostics
