Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Replace Tie Rod Ends
Step by step instructions for do-it-yourself repairs
How To: Replace Tie Rods DIY
I use plumber's teflon tape to mark where the new tie rod end must sit. If you want, a small dab of marking white paint will also do but paint has this way of seeping on the threads. Alignment has been near accurate but usually if you time this along with shocks or control arm bushings or some sort of suspension work, it makes sense,
shouldibuy (04-27-20)
New ends installed on both sides. Car feels great. Steering is more firm and smooth. Less rough road transfer to the driver, less bump steer, better braking. Nice change overall and I'm now not worried the alignment going out due to the tie rod not staying tight. I'm a fan of Beck Arnley parts.
New ends installed on both sides. Car feels great. Steering is more firm and smooth. Less rough road transfer to the driver, less bump steer, better braking. Nice change overall and I'm now not worried the alignment going out due to the tie rod not staying tight. I'm a fan of Beck Arnley parts. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
a friend of mine thinks he can eyeball things with alignment and it be 'good enough' for him. needless to say, he has horrible toe/tire wear issues in the front because he doesn't want to go get an alignment.
With the help of this thread I completed these last night. Overall very simple. Some notes below:
--I left my tie rods connected to the lower ball joint to unscrew the jamb nut. I was having a hard time getting the right angle/leverage with two wrenches. Worked perfectly
--I marked the tied rods (old and new) with a thick marker as well as the jamb nut to count the rotations upon removal.
--The Moog tie rods are nice, but would also recommend a non greased one. It was tricky figuring out how much grease to put in as once they are installed you can't grease them. Brilliant. I think I over greased them.
Thanks to all for the feedback and encouragement to DIY on our cars!
400 Degrez
Suspension and Brakes
19
01-02-07 01:34 PM
bazop
03-03-06 08:26 AM
